Replying to Topic 'Speakers pop when wakeplate is used'
Tom,
Rule number 1. Don’t always take what the dealer says as gospel. Yes, they work on the boats all the time, but that doesn’t mean that they can’t be wrong.
Come the end of the day, you may very well end up being right. I just want to offer you all the diagnostic procedures I can before you tear your boat apart rerouting cables for something that might not be the problem. There are several procedures you can follow to isolate the source of the interference.
1. Disconnect the RCA patch cables from the CD player and leave them hooked up to the amp. Power the system up and hit the trim switch. If the noise is still there, then you know it’s not coming from the preamp stage of the CD player.
2. Reconnect the cables to the CD player and disconnect them from the amp. Again, fire up the system and hit the trim switch. If the noise is gone, then you are correct and it is being introduced somewhere along the path of the patch cables from the CD player to the amp. If the noise is still there, then you KNOW it’s not your cables and we’ll keep going. If it is the cables, then I’ll get to that in a minute.
3. If the noise was still there in step 2, then your interference is being introduced either in the amp or in the speaker cables running from the amp to the speakers. Assuming that the amplified speakers are on your tower, and that the tower is grounded to the electrical system (perhaps for lights???) a chafed speaker wire contacting the tower could possibly be contacting the tower and causing the noise. This is unlikely, however, because the noise wouldn’t be strictly when you activate the trim tab. It could also be coming from the amp itself, which would mean that the hydraulic pump is dirtying up the supply of power and causing the noise.
Ok, if you have isolated the noise to the cables, then there are a few things you should consider. It is not ABSOLUTELY necessary to isolate the patch cables from the power cables. Yes, for maximum audio quality, they should be kept apart, but a ski boat is hardly an anechoic chamber and since the power and ground cables are running directly to the battery, the battery itself will isolate most, if not all, noticeable electrical noise between the different components connected directly to it.
The fact that the noise is only present when you operate the hydraulic pump, and not any other electrical device, leads me to believe that the noise isn’t being introduced into the patch cables from the amp power and ground wires. Now, if the patch cables get anywhere near the power cables for the pump, then that could very likely be the source of your noise. If the cables are near the relay for the hydraulic pump, then the spark in the relay when it closes would DEFINITELY create RF interference that would lead to your noise.
If you’ve isolated the noise to the cables, here is what I would do before I started tearing the boat apart to reroute the cables. Go to walmart and buy a cheapo set of patch cables. You can return them when you’re done and get some quality ones at an audio shop if you find that you need them. Don’t install them into the boat. Just hook them up to the CD player and amp and drape them across the boat. Now check to see if it still makes the noise. If it still does, it is unlikely that moving the installed cables will help. If it doesn’t, then start moving the cable around the boat trying the trim switch with the cables in different places to see if you can find where the noise is coming from.
OK, that’s all I’ve got for now. It would help if you could clarify the nature of the noise. Is it a single pop that happens just when you hit the switch, or is it continuous the whole time the switch is pressed? Also, is a pop, or more like a crackle, buzzing, or whirring noise?
Also, if neither you or the dealer can figure it out, just drag the boat down to a car audio shop and let them listen to it and tell you what they think. They know a whole lot more about this stuff than you, me, and the dealer combined.
Good luck
Cheers,
DKJ
1992 Supra Mariah - Red
OJ XMP 4 Blade CNC 13x15.5RH
