Replying to Topic 'Speakers pop when wakeplate is used'
That sux bro. Dont give up though, and dont think that it was a complete waste of time; at least you know you'll have a clean signal for the amp except for the pop. You've also learned the valuable lesson that you should always test to see if something is the problem before taking the time and expense on an unsure solution. That was the purpose of my long and drawn out previous posts.
Look on the bright side, you've at least isolated the source somewhat now, you just have to find the cause. If you havent completely given up, run a set a of temporary ground and power wires directly from the battery to the amp. Also try disconnecting the antenna lead from the amp. Give it a shot. A little trial and error, and we'll get this thing pegged.
To everyone: Enjoy your 4th of July, and dont forget the brave soldiers that gave their lives to give us a country so great, that we consider a pop in our speakers to be a major problem.
Cheers,
DKJ
1992 Supra Mariah - Red
OJ XMP 4 Blade CNC 13x15.5RH
