Guys,
I was wondering if you could help me out on this? My 2005 Supra speedo is not working, however, my speed is showing up on the peferct pass. Anyone have this issue before?
Guys,
Mitch Salazar
2005 24SSV
Could be something simple as a loose wire somewhere. All the pounding these boats take its not unheard of. Trace them all. But could be the paddle wheel has pooched. FFT
2009 21v Worlds 340 Cat
Doug
Doug,
I don't think it's the paddle wheel, if the perfect pass is showing the speed? Are the 2005 all electronic, or do they still have a pitot?
I have the same boat and it doesn't have a pitot. I have no idea why you'd have one and not the other, short of an electrical issue? I believe both the perfect pass and the speedo are fed from the same paddle wheel underneath the boat. Just under the dash, to the left of the steering wheel there's a knob that lets you adjust your speedo. Make sure that isn't maxed one way or the other, that might cause the speedo not to read anything at all. If it's not that then it sounds like the gauge has gone out on you or it's somehow worked itself unplugged. I know my tech told me to always check the plugs under the dash to make sure they had a good connection because they had a tendency to come unplugged every so often.
2005 Supra Launch 24SSV
Thank you guys. I will check it tomorrow to see if thats the problem. Thanks again for the feedback...
Mitch Salazar
2005 24SSV
Any luck with the speedo? I am currently having the same problem on my 2003' Launch SSV. Perfect Pass reads fine, but the speedo needle doesn't move. It used to work.
Did you ever figure out what the problem was my 2003 has the same issue.
