Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Impeller
    Jul 2009
    Louisville KY
    Default Impeller
    When does everybody switch out there Impeller? Every season or longer? Last time I changed mine was the season of 09... I think I'll go ahead and change it out this season.. Just to be safe!
    Oct 2011
    Jonesboro IN
    This is my first year dealing with a nondrive mounted pump.
    I replace mine every spring. I am sure they will go much longer but how long I dont want to find out.
    Impellers are cheep an overheated eng can be big money
    Aug 2009
    London, Ontario, Canada
    If you have a raw water strainer the last much longer or if you boat in crystal clear water. I have a strainer and the longest I've let mine go is 3 years. Even at that point it looked brand new.
    2009 21v Worlds 340 Cat
    Doug
    Sep 2010
    Collegedale, TN
    I haven't owned my Supra very long, but in all my other boats I always went about three years also and they still looked new. I'm sure boating in shallow waters could decrease the life expectancy, but I think an annual change is a little too much unless you're running a thousand hours a season.
    1986 Saltare
    Oct 2011
    Jonesboro IN
    Im not saying you need to change them every year.
    All I have owend to this point where mercury outboards or strern drives with the worlds worst impellers.
    Sep 2008
    Parkersburg, WV
    There's no need to change it every year, but it should be inspected annually. If there are any cracks or if it is brittle, pieces missing, etc then replace it.
    FYI - when I winterize my boat I always remove the impeller for the winter so that the veins will "relax" and not take a set. I figure if I'm going to inspect it in the spring anyway, I may as well remove it when I drain the water out in the fall. Just gotta remember to put it back in!
    Clint
    www.waketheworldwv.com
    Jul 2010
    N.W. Suburbs Chicago, IL
    Hey Clint, I do the same thing over the winter. I leave the impeller out over the winer, actually it is sitting in a ziploc bag right now in a small boat tub with the keys as my reminder to put it back in before I start it.
    '86 Comp TS6M - Reborn 2016
    Riding a HO Sports CX Ski
    Aug 2010
    Oyama, B C , Canada
    Impellers are inexpensive and easy to replace. Change mine out every year for a new one. No worries!
    Eric
    '89 conbrio
    Sep 2004
    Hudson, WI
    I replace mine every spring. Cheap insurance. Keep the old one as a spare. Rarely need it, but it's good to have.
    Feb 2011
    I had mine replaced this last fall when winterized, the boat was 3 years old. It looked like new. No way I'm replacing it annually after seeing that.
    2009 21V
