Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Oct 2011
    Jonesboro IN
    Default Fuel tank removal
    I need to do some work on the rudder of my 90 bravura.
    I cant for life of me get the fuel tank out it's empty and lose just will not turn to come all the way out.
    Is the somthing am missing.
    Thanks john
    Sep 2010
    Collegedale, TN
    The tank sits on some foam type of material. Over the years it may have semi-melted from the heat and essentially glued the tank to the floor. Once your connections (vent, fill, fuel line, etc) are removed, and the straps are removed, then tank should come right out. See if you can tell if the foam is causing you problems.
    1986 Saltare
    Oct 2011
    Jonesboro IN
    She was basicaly glued in. I got that loose all the lines and sender wires are off.
    I can lift the tank up to lip where the trunk sets. Its just will not fit through the hole and no enough room to
    turn it up on end edge so it will come out.
    Sorry I didnt explane my problem better thanks for your time.
    Sep 2010
    Collegedale, TN
    Oh, sorry about that. I'm not familiar with the specific interior layout of the Bravura. I would have thought it was similar to the Saltare in that you simply remove the ski locker and lift the tank out.
    1986 Saltare
    Oct 2011
    Jonesboro IN
    I wish
    Its just my luck to stumble in to an odd ball.
    I think I have come up with a new plan. Will haft to waight till tomorro.
    Apr 2002
    Austin
    tank on my saltare was very tight.
    slide tank to one side of boat as far as you can...i think the filler side. lift the opposite end up and start working it around. you'll find the magic angle.
    Aug 2009
    NW Houston
    Don't know about the Bravura but on my 89 Salt I had to slide the tank forward to remove it. The back corners of the top cap inner skirt liner had been notched just in front of the tank where they meet the floor for clearance.
    Hmmm. On my '90 sunsport I removed the rear bench also. Super quick and easy and made it MUCH easier to get out.
    Sep 2010
    Collegedale, TN
    Quote Originally Posted by cavilry View Post
    True. I wouldn't want to remove the tank without removing the seats first.
    1986 Saltare
    Oct 2011
    Jonesboro IN
    I was finaly able to get it out.
    The tank turns up on its side to come out only problem there is no enough room to flip it till you take off part of the blower system.
    Now on to the rudder
    How much slop are these things suppost to have. I belive mine is the rope packing style.
