This would be a better article if they got more detailed. What brand and grade of oil was tested? As others have said what about synthetic oil its viscosity doesn't break down. Are they saying that 30 hour changes cures the problem or just covers the oil consumption. What if you just check and add oil as needed and change at 50 hours. Is 5700 lbs of ballast common in your wake boat ? I'm way under 2000 in one boat and 0 in the other where does that put me as far as oil changes?
