Results 1 to 6 of 6
    Aug 2005
    Default New boat need suggestions
    Just bought a 94 ski supra comp, the boat is set up for skiing ( no wake at all ) Does anyone have any suggestions about what I should use as far as weight distribution, how much weight to be added balast, anything would be appreciated. One problem I have with adjusting the wake plate up is the boat wants to rock up and down when I have planed out. Do I need more weight under the bow?
    JB
    Jul 2004
    Austin, TX
    Default Replying to Topic 'New boat need suggestions'
    I've got an '89 Comp, basically the same boat. I run a pair of Fly High sacs on each side of the motor. Pull the sacs as far back as possible. I also use a block sac to compensate for side to side weight distribution. I put links below to the sacs I use. You can't beat the Fly High Pro X Series sacs. I highly recommend them. Also, adjust your wakeplate up.
    http://www.buywake.com/catalog/detai...p;sku=FL_EsUTZ
    http://www.buywake.com/catalog/detai...p;sku=FL_kuQpE
    Oct 2004
    Im 6'4" and 260lbs.... And I always bring a fully stocked cooler~!
    Apr 2005
    Clermont, Fl (wakeboarding capitol of the world)
    I just bought two of these for my Outback to weight it down for wakesurfing:
    http://www.bartswatersports.com/cata...ncer/index.asp
    folks at Bart's say forget the cases. You don't need 'em.
    Feb 2006
    I have a 90 comp and I only use one 400# sac in the floor behind the engine box. It helps, but I am thinking of going to two side sacs myself. I just wonder how bad water will come in when the boat sits that low. I took my wake plate off last year and the boat rocked real bad when the rider went off to the side. Not cool. Didn't change the wake much either.
    Feb 2006
