My 1989 pirata still is running points and condenser. So I think it is time to switch it to an electronic ignition. Any suggestions on what to use and where to get it?
Petronix is my vote.
Discount inboard marine has them
Why do you want to change? Does it make the boat run better? I was thinking about doing the same thing.
1986 Supra Comp
351 Windsor
Do it right the first time and buy the matching coil with it. This way you can delete the ballist resistor. Coils have resistance ratings and it is a pain to find one with the right specs at the autoparts store I found.
2003 Supra Launch 22SSV
1986 Ski Natique 2001
