looking for a surf boat. can you get enough wake out of a 1989 Conbrio? found one im thinking of buying
Not an ideal surf ride but it can be done
I used to have a '90 conbrio and it is very hard to weight them enough to get a good surf wake because it sits so low in the water. However you make want to hit up "Jet" on here. He is not running a Conbrio he has a comp but I know he runs ALOT of ballast. It seems like the Comp's can handle more weight because of the closed bow. When I had my Conbrio if I wasn't careful while crossing wakes when I had a few people on the boat it would take on water over the bow. Just a few things to consider
2000 Mastercraft X-Star 310hp approx. 2000lbs ballast
1990 Supra Conbrio
You can, but is it ideal? No..
I have a 98 comp. I run 350-400 in the back locker, 250 in the nose, and a 500 lb bag on the side we surf on, along with 3-4 people sitting on the rub rail.
A great surf wave, but you have to know how to drive...
