Results 1 to 8 of 8
    Jun 2012
    Sacramento,Ca
    Default 87 TS6M Bilge Pump Location?
    Feel like a total tool asking this question..lol But how do you get to the bilge pump on an 87 comp? Is there an access panel to get to it? I see where the hose runs in the bow and have an idea but don't see any way to get to it. I am bringing on a decent amout of water and pump is not working at all. Had water all the way up to the remote filter on stringers yesterday. Glad I had another bilage with me for filling ballast bag that I was able to pump water out with so I made it back fine.
    Jul 2010
    N.W. Suburbs Chicago, IL
    Should be a round black access panel near the ski pylon and captains seat in the floor, pop that sucker off and the bilge pump should be there or just a little forward of that hole.
    '86 Comp TS6M - Reborn 2016
    Riding a HO Sports CX Ski
    Aug 2010
    Ma/Nh
    also a little forward inside that access hatch are a couple of bolts that, if they've loosened up, can let a good deal of water in.
    __________________
    87 Comp
    Jun 2012
    Sacramento,Ca
    I do not have the access pannel on mine. I think when they removed the ski pole and did new interior they never put it back in the new floor? Would it be possible to get a measurement from engine cover to center of panel from someone so I can cut a new one?
    Jun 2012
    Central Wisconsin
    i will measure mine tonight and let ya know. i have a 92 comp so it should be similar...but
    every boat is different so not sure it will be exact, but should give you an idea.
    -Mike
    92 Supra Comp
    351 PCM
    Sep 2011
    GA
    I have a Sunsport, my front access is two or three inches off the front seat in the middle of the boat. I would cut the carpet with a knife, then use a saw an cut the wood out. Then install something like this to make it easier, you can always go bigger if you wanted though.
    http://www.overtons.com/modperl/prod...6&merchID=4006
    Shane
    "The man who smiles when things go wrong has thought of someone to blame it on." Robert Bloch
    Mar 2012
    Michigan
    on my 89 comp its 6 inches forward from ski pole (9in from engine cover mount) and 4 inches over from the 6 in mark, that would be the center of the hole. your end location would be center of the hole
    Jun 2012
    Sacramento,Ca
    Thanks for the info Ill get it figured out thats what I thought but just making sure. Kinda hard to see the bilge with the motor installed.
