So I'm trying to figure out what to do about my ballast system.
I didn't think that I had a problem with wake size or fill speed until I rode behind my buddies 08 X45 and then I realized that my wake was tiny and I barely get the same pop behind my boat. The fill speed isn't that big of an issue but I'm so tired of having to constantly mess with the ballast system to make sure everything is working correctly ie. are my pumps primed, is everything empty all the way, is everything completely full. I just wish it worked better.
As everyone knows the factory hippo ballast system pretty much sucked. I've had my boat for 2 years and every year I seem to have to keep messing with the ballast system and it never seems to get much better. I currently have removed the factory manifold and built my own manifold out of PVC and I'm using two intake pumps. One pump is an Attwood A750 and the other is the stock Rule 1100 feeding into 1 stock sprinkler valve feeding the non surf side sack and then 2 of these Orbit 3/4" Valves feeding both the center bag and the surf side bag. Everything is pulled through the stock intake scupper and emptied with stock pumps through stock lines and locations.
I currently have replaced the stock bags with 2 old school fat sac 750's that I've had forever and the center bag is still stock. I'm toying with the idea of purchasing the center gravity games 1100 but don't really want to spend that much money. But I also want a larger wake. I'm thinking of upgrading the center to Gravith Games center and keeping the stock center for use while surfing instead of unhooking the non surf side sack and moving it over. Question about GG center bag in my boat is will it actually fit? It claims to be quite a bit longer than stock and it seems like my stock bag fills most of the compartment already.
I want to either upgrade to 3 Tsunami T800's with vented loops and check valves utilizing the stock scupper location but removing the grating just like what was stickied in the modification section by FMAN. Or upgrading to get 3 jabsco reversible pumps (I can get a pretty good deal on them) and still use the stock intake. So what is everyone's opinion on what would be the most cost effective/efficient/reliable route. Would it be necessary to add more intakes with either option? I don't really want to if it's not going to help considerably.
Is it possible with the new GG center bag to get a wake comparable to my buddies boat. The more I ride behind his boat the less and less I like my wake.
