Another shaft packing question
I was replacing the shaft packing on my 24 SSV today, and I have to say that it wasn't as bad as I was expecting. And I highly recomend PB Blaster if you have tight nuts.
I was a little surprised to find 4 rings of GFO packing fiber, and they looked pretty good too. I had a constant trickle of water coming through the shaft seal without the boat in gear at all the last time we went out. So all that said, is 4 rings the number that I should put back in? I'm putting the regular wax impregnated material back in because that is what I have. Will be installing tommorrow. Info tonight appreciated.
2005 24SSV
5.7 Indmar 340hp
