Results 1 to 7 of 7
    Oct 2009
    Norris Lake - TN
    Default Quick Starting Question, probably an easy answer
    so i am still a newbie when it comes to engine problem diagnosis
    my boat worn't turn over or even click:
    yes, i am in nuetral
    yes, the battery is charged
    what are some areas i should check?
    i believe the starter is less than two years old
    what are some things i should check?
    please be detailed
    and yes i appreciate your input
    thanks!
    Oct 2011
    Jonesboro IN
    Try moving the shifter sack and forth wile holding the key in start position.
    If you can put a test light on the starter side of the solenoin have someone turn the key this will tell you if you have power that far
    Jul 2008
    Steamboat Springs, CO.
    Have you checked your neutral safety switch?
    Apr 2012
    Tacoma, Wa
    What boat?
    2003 Supra Launch 22SSV
    1986 Ski Natique 2001
    Oct 2009
    Norris Lake - TN
    nuetral saftey switch?
    what is that, and where is it?
    i have a 86 supra sunsport
    Jul 2010
    NY
    Neutral safety switch may be on the top of your transmission. I have an 89 Mariah and the switch was OK but my shift cable brass ends were worn,causing intermittent start problems.
    Apr 2012
    Tacoma, Wa
    Run a jumper from one terminal to the other this will bypass the switch to rule out a faulty switch.
