I just got the following fault warning on my 2010 Sunsport
dct:1626 can-j1939 tx fault
Not sure what it means but would appreciate any comments
2010 Supra Sunsport 22V Worlds Addition
I'm not too familiar with the operation of the newer boats, however I do engine calibration work so I am familiar with these fault codes, especially related to engines .
DTC1626 is a diagnostic trouble code. This code you are seeing CAN-J1939 TX fault indicates there is a transmit issue on your CAN-J1939 line which is a standard used for communication and diagnostics on vehicles. After doing some digging, in automotive/passenger car, this DTC P1626 sets if there is a communication issue with the theft deterrent system or fuel enabling system.
A couple questions:
1. Are there any other codes present?
2. What engine are you running?
3. Were you running the boat when you got the code or was this on a startup?
'89 Conbrio
