Results 1 to 6 of 6
    Sep 2002
    north carolina
    Default bertha ballast tanks
    we just got our new launch and we're still gettin used to everything. we got the optional bertha ballast system and i decided to check out the tanks. i know the one in the front is under the locker and i can get rite to it. im not sure where the other tank is and i have no idea how to reach it. if n e body knows please lemme know. thanx
    later
    ~grady
    Sep 2002
    north carolina
    i know the tank is rite under the seat but how do i get to the pump to c if its connected?
    later
    ~grady
    Guest
    Default Bertha tank
    Grady, waz up? The fill pump for that system is located in the bilge under the alternator. The drain pump is loated externally on the bottom of the tank (backseat bottom), which is accessable by removing the motorbox and rear center floorboard, there are 2 fittings on the top of rhe tank as well, 1 for filling and1 for venting the system.
    Guest
    Default Bertha tank
    Guest
    Default Bertha tank
    Aug 2002
    Tn.
    Default Ballast tank
    Bertha tank
