Condensation in the tank is so minuscule that it's not worth talking about. A fresh tank of gas (45 gallons) and some Sea Foam will quickly take care of the 1/2 oz that may accumulate. My main boat is 23 years old and never a motor issue, compression is perfect,does not burn any oil, and runs like a top. And, I change the oil every spring. My other boat has been in the family for 80 years, compression is perfect, doesn't burn any oil and runs like a top. Changed the oil every spring. Keep in mind that most oil manufactures state that you should change your oil if you have stored you motor for over 3 months. So, then if you change it in the fall, you should change it in the spring. I guess, I like to do it just once a year, and it hasn't caused any ill affects. My two cents, your choice.
