Is there any objections other than cost to using a full synthetic?
What year boat and what size engine?
I was wondering about this also. I have heard Royal Purple is good to use in the 5.7L.
I have been running Amsoil for many years in my pcm 350, not a single problem or complaint.
I have run Mobil 1 15w50 in my 89 since break in has 770 hours now no problems.
Your not supposed to use synthetic till after 100 hours. fwiw
2009 21v Worlds 340 Cat
Doug
I used synthetic on almost everything I own. I struggle on the decision to put it in the boat though, because I change it every season and the amount of use is so low. It seems like a waste to run synthetic for 5 months and only every other weekend.
But no, I don't think there are any objections. After the recommended break-in, you're not going to hurt anything. I just wonder if you get any benefit out of it.
I remember the 35 hour years when I lived up north . Here in Georgia the season is so long and I am so close to the lake I average 250-300 hours a year. That's 5-6 oil changes a year. Even at that I still use the synthetic I feel the extra protection is worth the extra cost. Note the older flat lifter engines require ZDDP additive . Mobile 1 15w50 has the additives for older engines some of their other weights do not.
