Smart Plate fuse location for 2010 Supra 21v
I was out on the water this past weekend and noticed that the Smart Plate was not going up or down and not responding even when I used the manual trim tab or Vision setting for an individual rider. When I use the manual trim tab located on the steering wheel column there is no sound or anything. I'm assuming that this may be a blown fuse, so I did manually reset the main breaker, but even after I turned back on the power the Smart Plate still didn't work. I looked through the owner's manual and did not see where the fuse is located for the Smart Plate.
Where exactly is the fuse located for the Smart Plate? Also, what else can I check on or do to fix this?
My boat is about a two hour drive to the nearest Supra dealer, so bringing it in would be a major hassle.
My boat is a 2010 Supra Launch 21v.
Thanks for any help you may be able to provide.
'Hitting Cliff Lee is easier than it looks' - Third Base
