Results 1 to 4 of 4
    Feb 2004
    Loveland Colorado
    Default 03 Launch dimensions
    Can any one give me the standard dimensions for the 03 Supra Launch? I have a company that wants to do a radical wrap on my boat but I can't find the dimensions in my paper work.
    Supra Rules
    Apr 2002
    Florence, AL
    Default Replying to Topic '03 Launch dimensions'
    2003 Launch
    Length w/o platform 20' 11"
    Length 22' 7”
    Length w/Trailer 24' 7”
    Beam 95"
    Draft 24"
    Boat weight 3,250 lbs
    Weight w/trailer 4,300 lbs
    Passenger capacity 13 ppl
    Weight capacity 1,775 lbs
    Fuel capacity 37 gals.
    Engine 320 HP
    Straight off the Supra website.
    DKJ
    1992 Supra Mariah - Red
    OJ XMP 4 Blade CNC 13x15.5RH
    Guest
    Hi
    What is the fuel capacity of an 89 conbrio?
    tom
    Apr 2002
    Florence, AL
    Originally posted by Guest
    Hi
    tom
    Welcome Tom,
    First, you have to register and log into your account for your post to show up on the main board. Otherwise, the only way people will see it is if they reply and look at the message history on the reply screen.
    The tank on my '92 Mariah 21' is 37 gals. The Conbrio was a 20' model, but i would imagine its pretty close to that. If yours is like mine, the fuel tank is under the rear ski locker at the back of the boat. If you REALLY want to know for sure, you can pull the screws out of the locker (i suggest a power drill for this if you dont like hand cramps) and the whole plastic tub of the locker comes right out. There should be a label on top of your tank stating the capacity. I'm pretty sure the label HAS to be on there for USCG regs.
    Alternatively, you could just run the tank dry, paddle to shore, and see what it takes to fill it up. Just get ready for sticker shock: Our marina has plus unleaded for $3.15 a gallon. That comes out to $116!!! I'm just glad none of my friends slalom or barefoot. The boat isnt bad on gas until you get into the secondaries at about 35mph. At that speed you can almost see the fuel gauge going down.
    Cheers,
    DKJ
