Page 1 of 8 123 ... LastLast
Results 1 to 10 of 72
    Nov 2011
    Paris, France
    Default DIY tower speaker (HLCD page 3)
    Hi Guys,
    As I can't work on my boat because of winter, I would like to share this tutorial on how to build your own tower speakers.
    I already gave all those informations in my boat's post, but it will be easier to find it in the audio/video section.
    So, I started to draw it on autocad (DWG here ; DXF here and PDF here) and CNC it in PVC Komacel/Forex material (20mm thickness) :
    Stéphane
    1989 Supra Saltare
    Nov 2011
    Paris, France
    Then I glued and screwed the squeletton :
    Stéphane
    1989 Supra Saltare
    Nov 2011
    Paris, France
    I then stretch sleece material (to make sweatshirt), 300g/m² to get the final shape and staple on the top of the face (with satinless steel staple) :
    Stéphane
    1989 Supra Saltare
    Nov 2011
    Paris, France
    Then i resin it with polyester resin. You can use epoxy, it's stronger, doesn't smell, but is more expensive.
    I bondoed staple and outcrop the face.
    My choice was to get someting different than painted or polished aluminium result, so i go with black vinyl, and a polished aluminium face. If you choose the same vinyl finition, becareful to use a good one, very stretchable.
    Notice that I put inside the box some anti vibration material, to loud the sound and prevent from vibration noises.
    Here is the result :
    Stéphane
    1989 Supra Saltare
    Nov 2011
    Paris, France
    The face is a 2mm thickness aluminium that I polished with standard polishing stuff and a driller. It tooks time and patience, the aluminium needs to be taped on a wood piece.
    Here is the final result :
    Finishing between alu face and vinyl is black silicon
    Stéphane
    1989 Supra Saltare
    Nov 2011
    Paris, France
    Speakers are BOSS AUDIO MARINE MR695. They do the job very well for the price, I don't regret my choice. They are powerful and sounds Hifi.
    Clamps are coming from DIYwake.com
    I then glued "SUPRA" in PVC material 3mm thickness
    Stéphane
    1989 Supra Saltare
    Nov 2011
    Paris, France
    And finaly some photos of the final thing on the boat :
    Stéphane
    1989 Supra Saltare
    Aug 2009
    London, Ontario, Canada
    Awesome job
    2009 21v Worlds 340 Cat
    Doug
    Nov 2011
    Paris, France
    Thanks docdrs
    Stéphane
    1989 Supra Saltare
    Mar 2010
    Arkansas
    Nice work, looks clean.
    Sent from my DROID RAZR using Tapatalk 2
    2006 Supra 24SSV
Tags for this Thread
