Throttle Lever Loose
I have a '98 Saltare and the throttle assembly at the cockpit wobbles. Does anyone have any suggestions on how to tighten this up.
Greg
hey greg,
is it loose where the unit attaches to the sidewall or is the throttle lever loose from the main unit?...i got to say unit twice in that question!
i think there's an allen screw on the lever at the bottom but i'd have to take a look at mine.
i've replaced my cables so i've looked behind the morse unit. there's not much to it, you might need a new one but i'd look for the screw first.
kevin
It is the entire unit that appears to be loose. There is a phillips head screw in the center of the neutral button. That was all that I saw. I tired to tighten it, but it was tight.
Greg
mine has 4 screws around the edges that secure it to the wall.
