In the owners manual for my 2008 Indmar engine, under the oil change section, within the oil change instructions, it mentions a 'QuickDrain'. It says to 'insert the QuickDrain hose through the drain hole in the transom, and drain into a bucket. I'm fairly confident I've found the hose, as it come from the bottom of the oil pan, but the hose is too short to make it through the drain hole! It's not even long enough to reach the transom, much less through the hole. Am I missing something here?
My next step I suppose is a trip to the hardware store to buy a threaded fitting and tubing in order to extend the QuickDrain. It's just perplexing that this hose is called a Quickdrain, but it's not long enough to do the job. Was trying to avoid pumping the oil out. No big deal, but if a "QuickDrain" is there, and manual refers to it, then would sure like to use it.
Had a Baja with the same, but the hose was connected to the drain plug, so when you pulled the plug, the oil drain hose was attached and followed.
