I'm getting ready to change the fluids on my engine, vdrive, and trans. A couple of quick questions as I've never done this service on my boats before, typically had a dealer do it.
What oil & filter do you guys recommend? I typically use Mobil 1 in all of my cars/trucks but didn't know if that was a bad idea in the boat.
Do you use standard Auto Trans fluid in the trans? Anything special with the V drive or just the recommended #30 heavy duty non detergent motor oil?
I'm planning on just using a simple vacuum pump to drain everything, any other recommendations?
