Results 1 to 4 of 4
    Oct 2009
    Norris Lake - TN
    Default Need your 2 cents on what cam to buy
    i have an 86 sunsport with a 351W
    me and "mostly my good friend" are rebuilding the motor
    we are replacing the cam
    i was told an "rv cam" is best
    i was also told to go back to original?
    i need to buy one asap, so any help would be appreciated...
    also replacing steering cable, any advice there would be appreciated to...
    thanks again
    May 2013
    dont know if you have bought a cam yet, but check out marine cams.
    any one of these are prolly good for you to use. not needing to make a ton of power.
    http://www.summitracing.com/search/d...nview=Vertical
    Sep 2004
    Hudson, WI
    Call comp or crane and they'll tell you exactly what you need based on your usage and performance. Anyone else is just guessing.
    Aug 2010
    NJ
    What heads? What rocker setup? What performance improvements are you doing other than a cam?
    If it's basically a stock rebuild I'm go with this cam: http://www.summitracing.com/parts/cc...view/make/ford
    If you've ported heads and mad other improvements then you may want a bit more cam but you have to careful about duration if you're keeping stock exhaust... Factory risers mix the water pretty close so you can have reversion issues.
