How many drain plug dose a 2000 supra launch DD have? and where are they located. I have found the drain in front of the engine. is this it or am I missing something? Thanks for the help.
Should be one in front of the engine, and one at the rear center of the transom (back of the boat). If there's not one at the back of the boat, crawl under the boat when it's on the trailer and look for any other holes in your boat. If you find none, the one in front of your motor could be the only one. Most direct drive's have two drain plugs though.
-Mike
2006 Supra Sunsport 20V
