1984 Supra Bow Rider 19
1984 Supra BowRider 19 - $7,500
19 foot Open Bow Ski/Wakeboard boat
Engine
Ford/PCM 351 V8
260 horsepower
Electronic ignition
Battery cut-off switch
Runs perfect, great hole shot
Original Sea Demon Carb (just rebuilt this spring)
New impeller
New Custom ballast system (750 lbs Fat Sac, 2 1200gph pumps - 1 fill 1 drain, with switches on console)
New ring gear on flywheel
New steering cable, console, and steering wheel
New shaft bearings
New bilge pump and wiring
New Blower
New Mirror
Interior
New floor, composite stringers and carpet 3 years ago
New vinyl (90%)
All new gauges (2 speedos, tach, fuel, amps, temp, oil pressure)
Depth finder
New Upgraded Throttle Control
AM/FM CD player with 4 speakers
LED accent lighting under gunwales
Wakeboard Accessories
Monkey Bar Tower
750-pound automatic ballast system, controlled from drivers seat – room for more.
WakeWorx Wakeboard rack
Trailer
Tandem Axle
New wheels, tires, bearings and lights
New jack
Miscellaneous
ACME 13” 3-blade prop
Maintenance
Oil changed, tranny fluid changed, new plugs annually
Pictures:
http://www.villagephotos.com/pubbrow...der_id=1712282
Note:
Previous owner let the boat get too close to a grass fire. Some of the gelcoat on the rear bottom of the hull is cracked and chipped. Fiberglass was unaffected and is very solid, and I’ve been running the boat for 4 years as is.
Replying to Topic '1984 Supra Bow Rider 19'
The boat looks nice, where are you located? This boat is what I'm looking for and I am definately interested. Do you have any contact info?
I noticed after the reply the date it was posted.
