I have a 1993 Supra Comp in excellent condition except the trailer pads at the V have worn through almost to the metal on one side which slightly scratches the hull when I pull it out of the water. Any ideas on how to fix the problem.
Could you explain in more detail where the wear is? I'm not quite following you. Its probably as simple as replacing the trailer carpet on that part.
DKJ
1992 Supra Mariah - Red
OJ XMP 4 Blade CNC 13x15.5RH
It sounds like you get a fair amount of use out of your boat. Be sure to inspect the bunkers themselves to make sure that the wood isn't softening up on you. If this is the case you will need to replace the bunkers and re-carpet them. If the wood is still in great condition I would recarpet these pieces with some good quality outdoor carpet.
