Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Apr 2006
    Akron, OH
    Default pylon for an 86 marauder
    can anyone tell me which flyhigh pylon I can get to work with my 86 marauder. My center bar has a t on the top so I cannont slide one on. Anyhelp on pylon selection would be awesome.. Thanks
    Nick
    2005 Moomba Outback LS
    Default Replying to Topic 'pylon for an 86 marauder'
    I have a "T" top on my pylon as well.
    I don't think they make any extended pylon to fit over them.
    You'll actually need to hammer out that little piece. I haven't done it yet... waiting to get an extended pole first.
    But, heard a hammer and piece of pipe to bang it on works pretty good.
    Apr 2006
    Akron, OH
    let me know how it works out for you.
    Nick
    Will do.
    a friend of mine did this before he got his monstertower a few yrs later. Said its not too hard to do.. Said it's easier with 2 people. 1) holding the pylon - just to be sure and to brace it, then him to bang it out.
    Apr 2006
    Akron, OH
    this has nothing to do with this post but what kind of boat do you have? My maurauder needs some dash upgrade. Have you done anything like that to your boat?? If so what did you use and some pics would be sweet. I am also looking to replace my floor and stringers but not sure if I am going to do it my self or take it to a guy in Tennessee. Thanks for anyinout and your help so far.
    Nick
    saw your post on the dash.
    I have a '91 Mariah open bow/PCM 351.
    I haven't done anything to the dash (other than recently replacing the key'd ingnition switch)... and just a wipedown with 303 that was suggested. Would like to take my gauges out at some point and repaint with some black as a few are chipping and starting to look worn.
    I have seen pictures of some dashes redone on the older supras. Most notible (but can't find the pics now) just replacing of the gauges and/or repainting the rings or "bling"ing them out.. saw one that had gold rings around each gauge... Mmmm ok.
    I would think you could probably change out each pushin switch to another kind of switch as long as it works in the same manner. Though, it might be alot of work if a toggle type switch or something else had a bigger/different size mounting. I think it can be done pretty easily, but will take time as you will probably have to take off the dash pannel itself and redo that so they all fit correctly. (sounds like a winter project)
    I'll see if I can find some of those photos I mentioned. Can't remember where I saw them..
    PS.
    My stringers are good, however- I'm starting to get a few soft spots in the floor. One board that is getting soft- is right behind the engine.. easy fix. Its in the middle of two others and is a separate peice.
    other soft spot is just infront of the pylon.. not as easy as the carpet doesn't separate there- and don't know if it's a separate peice of wood.
    But, If you have the time, replacement isn't too hard from what I've heard. If you take the time, you can actually peel off/back the carpet, replace the board, and reattach the carpet... well, if you carpet is still in good condition.
    I think if you can get a marine grade wood/and then even seal it more- it would work just fine.
    What does the dealer charge for that repair? Might be worth your time.. or maybe better to just bring it in.
    I will probably tackle this next winter before it get worse. But fine for this summer.
    Apr 2006
    Akron, OH
    thanks I get some pics of my boat up here once I figure out how to post pictures.
    Nick
    http://www.imagestation.com/album/pi...?id=2121573310
    Oops.. don't know why that posted twice.
    can shoot me pics (if you have some) thru email.. and I can post em.
    joe Dot selle @ wellsfargo dot Com
