Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
    Sep 2009
    Indiana
    Default Hydraulic/ Electric Wake plate upgrade
    Hi as the weather turns colder and it becomes apparent that there will not be too many more days on the water this year, I start to think about projects for the off season.
    My main goal for the boat this winter is to convert the manual wake plate to a powered wake plate. I really like the idea of the Lenco electric actuators but know that the bennet hydraulic are the tried and true.
    If you have upgraded I would like to see/ hear how you did it and what you used. I would also appreciate some pictures of the newer boats factory setup if possible.
    Thanks
    Derrick
    1988 Supra Mariah
    96Comp Guest
    Default Actuators
    I will be doing the same thing to my Comp this winter. Decided to go hydraulic. While the Lencos may be easier to install, I read too many posts on line where the motors failed. Makes sense because the motor and all controls are in the actuator. If the seal fails, the unit fails. Bennett also has a specific replacement kit for bottom mount plates, like mine and I assume, yours. The entire Bennett kit is $500, plus another $120 if you want the indicator. I plan on taking out the interior for some repaint and repair work, so that should save a little on the install price.
    Sep 2009
    Indiana
    Where did you find the bennet kit?
    1988 Supra Mariah
    96Comp Guest
    Default Bennet Kit
    Saw one on their web site and then called and spoke to customer service. They will fabricate the hinge for bottom mount in stead of transom mount. The two actuators mount where the manual tab adjustments mount on the transom. However due to the length of the actuators, it appears I will not get as much up deflection as I wanted, as in position for a surf wake. Still better than manual adjustment.
    Feb 2009
    Minneapolis, MN
    Mine is a Bennett and I would highly recommend them as a brand choice. Their customer service is one of those 'WOW' experiences.
    Sep 2009
    Indiana
    Mikey does yours use a single switch and do you have the indicators? If not do you wish you did have the indicators?
    1988 Supra Mariah
    Feb 2009
    Minneapolis, MN
    Single switch, no indicators. I can tell pretty easily by either driving and looking at the wake shape (set and forget for the session), or else the motor makes a different noise when high or low-point is reached. I have learned how many seconds that takes and can adjust accordingly.
    Sep 2009
    Indiana
    Thanks for the info guys
    1988 Supra Mariah
    May 2009
    Back to Dallas!
    96 Comp..we need to see more pics of your boat..she looks sweeet! Jet
    89' Comp rebuild thread:
    89' Comp Mod's and fun pic's:
    May 2010
    Dixon, IL and Columbia, MO
    Default Hydraulic Trim Tab
    Has anyone out there replaced the fixed trim plate with a hydraulic one? I'd really like to be able to control the trim a bit.
