Results 1 to 9 of 9
    Apr 2013
    Default weighting 07 21v for wakesurfing?
    I just got a 2007 Supra 21v and cant figure out how to weight it for wakesurfing. I have a 1180 bag in the center locker and the 650 bag on rear driver side cause I am left handed. I fill both of them and 2 passnegers sitting on same side riding about 9.2 mph. Is this enuff weight? Any suggestions? Thanks
    May 2013
    less weight in the center, more weight in the rear corner you are surfing on. you can go faster to make the wave longer, as well as adding weight to the front of the boat. i surf at 11.5 mph.
    Apr 2012
    Tacoma, Wa
    Mines not a 07 but I have to run a 750 in the rear surf side, another 750 on the floor on the surf side and my 1180 center full. 11.7mph with wakeplate 3/4 down. I'm 230lbs. my 14 yr old daughter who is probably 115 can do it with just the locker and front bag no problem. The bigger you are the bigger the wave needs to be. I was surprised it actually takes a lot of skill for me to keep going on the wake. there isn't a lot of just standing there like smaller people. I have to keep working the wake.
    2003 Supra Launch 22SSV
    1986 Ski Natique 2001
    Apr 2013
    Do either of u have a 21v and what 750 bag is good for rear locker?
    Apr 2012
    Tacoma, Wa
    mines a 03 22ssv. I'm using the Fly High pro X 750 bags from Wakemakers. I have two batteries in one and one in the other so the bags don't lay flat on the transom end. If I fill them all the way they will lift the cover a little. they fill the compartment side to side, front to back with the transom end laying on top of the battery covers. This is why the cover comes up. I also removed the front divider in the port side locker to make a little more room.
    Oct 2007
    brighton, il
    I have a 07 21v my standerd set up is a 750 in the rear, 1180 center bag full extra 400 in the play pen. with 3 or 4 people. speed about 10.8 mph wakeplate about 25% to 0% (most the way up)
    I feel this is a real good wake. also i adjust speed and wakeplate for the hieght and length of wake.
    if i only have two people with me or want a big wake. we also add a 400lb sack on the back sun deck or seat on the side we are surfing on.
    i think the rear drives side is a harder wake to set up i think cause of the prop spin. I think the only way to overcome this is more wieght in the rear.
    on a 750lb sac i just got a set from wakemakers and also got the extion hose kit it was plug and play.
    some people say do not mess with the 750's got to the 1100 lbs sacs. ( i thing after putting the 750's in you probaly could get about 900lb in the 1100's but you need to add extra suports in your center dividers)
    i think a few things to think about is the following and address your setup accordingly.
    i hope if i am saying this right someone corrects me am not.
    wieght in rear corner makes wake taller (steeper)
    wieght in front make the wake longer.
    up on plate make wake hieght taller and length shorter
    down on plate make wake hieght shorter and length longer
    speed will help clean the wake up and also more speed lenghts the wake.
    Apr 2013
    Wolff,
    What 750 bag did u get? Did u have to do anything to locker so the 750 bag would not mess anything up?
    Oct 2007
    brighton, il
    Here is a link
    http://www.wakemakers.com/supra-and-...r-upgrade.html
    i got the fly high 750lb 50"x20"x20". I also got the short hoses from them the new fill port on these bags is on the top instead of the back of the 400lb bags. i do not know where the 600lb fill port is but the factory lines was not long enough for the 750 sacs i got. it fits in the locker good i bought the set because we surf both sides of the boat alot. If all we did was surf i think i would of got the 1100lb bags.
    i have not put supports in my center devider. i check the hinge screws every now and than and the have not work loose and everything looks okay with it.
    Apr 2013
    Thanks!
    What is your best setup and speed for wakeboarding?
