Results 1 to 6 of 6
    Apr 2011
    southeast MO
    Default audio gurus please help
    does anyone know what causes speakers to hiss. sounds like air blowing. can only here it between songs or if volume is real low. the noise is constant but music normally drowns it out.
    Apr 2012
    Lake Wylie NC Area
    If it does it with and without the engine running, the leading cause is having the amp gains too high.
    Michael
    Mikes Liquid Audio
    Jun 2013
    Waterford, MI
    Default Re: audio gurus please help
    Does it vary based on engine RPM? May be hard to tell if it is drowned out. My first thought is that you may have a ground issue, ensure the connection is clean and in tact from the amp.
    Second thought is that if the rca's to the amp are run directly next to the power cable, that could do it. This is much more common in auto, not so much boats because of battery placement.
    Sent from my Galaxy Nexus using Tapatalk 2
    Apr 2011
    southeast MO
    at first I had alot of engine noise so I ran a dedicated power and ground for audio straight from battery. That is now fixed but this noise comes through with or without engine running. I think Wylie might be right because I didnt adjust my amps. just installed them right out of the box. Amps are new to me...
    Apr 2012
    Lake Wylie NC Area
    Quote Originally Posted by dirtydawg View Post
    Its very common for amps to come from the manufacturer with the gains wide open from their in-house bench testing. There are a handful of settings that need to be set correctly when installing an amp, gains being one of them.
    Michael
    Mikes Liquid Audio
    Apr 2011
    southeast MO
    thanks, I need to dig out the instructions and see how they adjust. they were cheap JBL's but I know there are some adjustments on them
