How do you get the rudder off????? I have taken out the cotter pin, removed the nut for the steering arm. The bolt for the steering arm will not come out. I have soaked with PB Blast, WD-40, Aerospace Lube. I understand the bolt has a scoop out of the shaft to wedge aginst the rudder shaft. I have beat the bolt and not luck. The only thing that is holding the rudder in is the cotter pin and I belive the packing nut does not hold the rudder. Please help!!!!!
REB
