It looks like I may have developed a transmission leak. I noticed a bit of fluid in the bilge Saturday at the lake. The bottom of the transmission case is a little wet with it but it wasn't crystal clear where it was coming from. I plan to dig into it this week to see what it's going to take to fix it. For those of you that have worked with the transmission, can you tell me where the various seal points are? Are there bolted areas with gaskets that just might need to be snugged up? Is there only special seals that require removal of the transmission?
For reference, it is an 89 Supra Sunsport with the PCM 40A 1.23:1 transmission.
