It's easier to ask for forgiveness than permission.
Sent from my iPhone using Tapatalk 2
Hahaha it has worked for me so far. But she understands that the boat comes first. Lol
I have the same distributor it’s really simple the way it works.. Take out the plate that the points are mounted to and look at the weight mechanism . Make sure that everything is moving freely, clean and re-lube everything in there. There should be 2 small light weight springs in there. If the spring are to strong it will raise the advance curve to a higher RPM. Someone may have installed the wrong strength of springs . It will work with only 1 spring . I have over 1700 hrs on mine I drought it’s worn out it just needs some TLC. You can get a spring kit at Napa $10. 19 degrees sounds about right. You can do this in less than a hr.
19 degrees is stock advance. Set base timing to 10 degrees, the distributor will advance 19 degrees more total 29 degrees advance by 1500 to 2000 rpm . I’m thinking that the springs are to strong. Or it needs cleaning. Book is inspect ,clean & lube every 100 hrs.
Yeeaah Daddy!! I can't believe my boat. I dropped a new distributor in it today. Took it to the lake this evening to time and test. Set timing at 10 degrees and gave it a try. It jumped out the water so fast, i was hardly prepared. That was some of the best money I've spent on the boat yet. So with a new prop and distributor, I am purring. It has taken care of all the problems we were having. Thanks for all the advise and input, I learned a lot through this issue. Rpms at 4,300 and speed around 45
Glad it all worked out. The good thing is you now know your engine and drive line much better than the average boater and will be ready for the next adventure with respect to issues on the lake. The thing to remember is to never give up and check the basics first.
Which Distributor did you end up buying ? I am having similar issues. A mechanic I talked to thinks the intake manifold the PO put on is wrong and not handling the fuel properly. I haven't looked at the timing yet, but after reading this thread its the next things on my list to do...
