Results 1 to 3 of 3
    Oct 2012
    Raleigh, NC
    Default Bulb Replacement for Roswell Light/Speaker Tower
    Hey Gang,
    I have a 2008 21V and wanted to know if anyone else has had an issue trying to replace a bulb on the Roswell Tower Light Bar? It is the standard one that came on the Supra's and Moomba's at the time. The light bar has a 3 light set-up that shines on the back on the boat to wake area. One of the bulbs went out and what I thought was a simple fix is anything but that. Turns out the bulb is soldered to the wiring. Any suggestions on the simplest way to change this out would be appreciated. Thanks.
    I had the same issue. You have to order the bulb from Supra. I have an extra that I can send you because I just went ahead and ordered LED Car FogLights from ebay and paid $5 a set for them. They use a fraction of the electricity, never burn out, bright as hell.
    Only thing is, save the brackets from the roswell fog lights.
    If your gonna change it, you gotta cut the wires, then re-solder them, and heat shrink them. I wouldn't use crimp connections up there.
    What exactly did you search for on EBAY for your lights
    ? I have same issue, soldered wire etc. I also do not have a Supra dealer anywhere close.
