Results 1 to 10 of 24
    Vancouver WA
    Default Clockwise vs CCW, LH vs RH, Standard vs Reverse? Help me get this down once & for all
    Okay, so I am trying to get this down, because different parts sellers will reference things differently.
    So please help me with this.
    There is ENGINE rotation (useful for buying parts that bolt on the engine like starters, alternators, etc) and there is PROP rotation, right?
    So for mine, would it be:
    Engine
    Left hand rotation
    Standard rotation
    Counter Clockwise rotation
    So does that mean that my propshaft would be the opposite??? Help me fill in the blanks and confirm so I don't someday order the wrong stuff.
    Prop
    Right hand rotation???
    Reverse Rotation??? <--do they even use this term when talking about props???
    Clockwise rotation???
    Thanks. I get confused about this too easily and I know it should be pretty simple.
    May 2006
    Nashville
    What you have to do is rather simple.
    First make sure it's the Autumnal equinox, which should be close so you're good. Don't do the spring equinox as it will be upside down. Now, take you first born, and stand them on their head. Put them facing North while they face the prop. Then find a virgin chicken, and then sprinkle it with Paprika from the Mountains of Tibet. Once you have done that, then sing the last line of Shama-lama ding dong, and then a small muchkin will appear. At that time the munchkin will then tell you which direction it turns.
    Good luck.
    Vancouver WA
    Good luck.
    I didn't realize it was that easy. Are you saying that I won't need the 47 virgins now?
    Jul 2011
    Atlanta, GA
    Oh good you already have the 47 virgins! The munchkin will only tell you the answer if you give him the virgins
    1991 SunSport
    Oyama, B C , Canada
    I can be a munchkin!!!!!!!!!!
    Jun 2013
    Albany NY
    I know this is a few days old, but a few other things you can tell:
    The first 3 letters of the ID tag are PL (PCM Left rotation) or PR (PCM Right rotation). The tag pictured above is PL.
    Also the firing order of the Standard Rotation is 1-3-7-2-6-5-4-8 and the firing order for Reverse Rotation is 1-8-4-5-6-2-7-3.
    And, you can look at the prop. If you have a 1:1 transmission then the prop turns the same direction as the engine, when going forward.
    Sep 2009
    Carrollton, VA
    Engine
    Left hand rotation
    Standard rotation
    Prop
    Left hand rotation is standard rotation, also the same rotation as an automobile engine. Standard rotation, when looking at the front will rotate to the right (clockwise), when looking at it from the prop it will turn left (counterclockwise ).
    https://forum.supraboats.com/showthr...9146#post99146
    Take a look at the 5th post down. I posted about this in another post about starters. There's a picture I refer to a lot.
    Nov 2008
    Walkersville,MD
    Thank you for that reference! I saved it, I know it will come in handy!
    -Rich
    Vancouver WA
    Quote Originally Posted by vvfdfirefighter View Post
    Thanks, that does help. So, I guess that means my starter is CW. Circled in blue.
    Sep 2009
    Carrollton, VA
    not a problem. Hope that answered some of your question!
    Sent from my Samsung Galaxy Note II using Tapatalk 2
