In the middle of trying to revive the 88 Saltare I ran into a little snag. The 454 was recently rebuilt prior to me getting the boat because of a cracked block, but had some issues. Started getting a tick from the top end so I pulled valve cover and everything seemed good. But still had tick. Being a little nervous about the motor I decided to pull it and tear it down for inspection. Found a bent push rod plus, rod and main bearings shot. Luckily no spun bearings. So hopefully, get the crank turned, new bearings and seals, the bottom end should be done. The top end is where I am a little undecided on. Everything intake wise is stock. I am thinking of possibly going with a Edelbrock kit (carb, intake, cam). Versus sticking with the old manifold, carb and new cam. Also probably going to do a little vanity work also and get the exhaust powder-coated. But never mind that. Who has any recommendations on intake set ups? Stick with stock and rebuild the holley? Go with the Edelbrock kit? Anything else out there? My end goal is to have a smooth running boat that has plenty of low end power, low maintenance, and an engine that looks as good as it runs.
