Well I have reached that point of no turning back! I am finally going to tackle a rebuild this winter. Our boat has had a few soft spots in floor and motor mounts aren't as tight as they should. I have held off for a year or so longer than I wanted to. We have been taking on water on the drivers side of the boat. The floor on that side will get wet after a while on the lake. So here we go. I have read every one of you're rebuild threads that I can and am actually looking foward to doing this.
I got started tonight and have some serious questions right off the bat. I can't decide if I'm the first one to do stringers on this boat. As you can see in the pictures below, the wood is in good shape. But the fiberglass is not laminated to the wood at all in some places. I ripped the fiberglass off the outside stringer on the drivers side and it is a piece of treated wood. ????? That didn't come from the factory did it? Also, the foam isn't solid, it is just a pile here and a pile there. What do you think I have going on? The driver's side needs redone. The foam was wet from the bottom to about halfway up. and the treated boards are not solid without the fiberglass holding them. But the other side of the boat is dry as can be. The stringers over there are the same wood, but look great. Here are a few pictures. Any feedback would be awesome.
