I know this has probably been beat to death but want some direct answers. This winter I will be replacing the floor due to 3 soft spots. First off i have a 90 Supra Comp. I am going to replace all the wood floor but this go round i do not plan on using marine plywood, so what is the next best option from local lumber yard or home depot? What kind of resin and glass will i need to use to coat the plywood with? My stringers look good and motor mount bolts are extremly tight and can't be spun. My foam feels dry but if i stab a screwdriver in to the middle it is wet when i remove it. So if i wanted to replace the wet foam what foam do i use? I am ready to go pick this stuff up and just wanting opinions and names of plywood, resin, glass, foam to purchase and where. My best friend is a Trim Carpenter and is very good with wood (haha) but i'm just needing to know what to purchase. Thank you for helping out.
