Originally Posted by
haugy
Don't forget to put flame stickers on the valve covers, that adds 15 horsepower right there.
Make sure they are chrome valve covers with a matching chrome air cleaner, they shoulbe be good for about 5 horses at the prop. add the flame stickers and you will be the fasted ski boat on the water lol
seriously tho, i would strongly consider a full rebuild if its finacially feasable. like people said, its not that much more expense or work, and the heart of your boat will be brand new. who knows how much metal from your worn out, ticking lifters has found its way into the connecting rod and main bearings? as also noted, the tick may be due to poor oil pressure or gummed up oil passages inside the motor... if thats the case, who knows how much damage has been done to all of the wearable surfaces inside your engine? if the oil pressue is weak due to a bad pump or clogged up oil passages, there is no doubt that premature engine wear has taken place. the question is: how much wear? if it were me, since its a boat, and not exactly like you can call a tow truck like if your car broke, id replace the piston rings, rod bearing, main bearings and oil pump at the very least, just for some peace of mind.
1988 Supra Sun Sport 454 PCM
1972 Olds Cutlass 455
1998 BMW 750il
1996 BMW M3 coupe
1995 Toyota Tacoma 4x4
