It must have leaked out or I suppose if you had a small leak in the cooling chamber it could have been sucked out. I would take a paper towel to the bottom of the vdrive to see if there is any oil on it. If its dry then you could pressure test the cooling chamber. But I would fill it up again and then check the level every time you run the boat and watch the red light to see that it goes off
