Results 1 to 10 of 20
    Apr 2010
    StCharles Il. 30 mins west of Chicago
    Default 83 Supra Beast !! 454 engine over heated, now ticking- Help!
    Hi everyone!! Here's what I have going on.. I've owned my Supra Beast for 14 years now, and have completely restored it twice.. Last fall my impeller failed and the engine got way to hot and now its 'ticking'.. Its definitely not knocking, so I'm hoping It can be delt with without pulling the engine.. Has anyone here delt with this problem before?? What am I to expect? Thanks for ANY information or experiences..
    -Brian
    NJ
    Ticking or higher pitched sounds are typically top end. Lower pitched knocking or thumping is typically bottom end. Could be a lifter/rocker/valve problem. How hot did it get? Any water in the oil? Any metal or shiny particulates in the oil? My first step would be try to figure out which side it's on and pull a valve cover to inspect.
    Apr 2010
    No water in the oil, and the engine got hot enough to smell. the temp gauge was pinned... I did take the cover off and it sounds like the ticking is coming from the rear passenger cylinder. I tried to adjust the valve lash and in order to stop the ticking, i have to tighten the bolt so much it makes the engine run rough. I'm thinking bent valve stem?? or ?? .. Would it be common for the cam to be ruined?? I'm hoping I dont have to pull the whole engine....
    Sep 2004
    Hudson, WI
    Is it running OK? Compression? It's not the most far-fetched idea in the world that it was ticking before but you didn't notice it or pay attention. A mechanics scope and a leak-down test can tell you a lot....
    Apr 2010
    If I recall, the compression was fine, but I never did a leak-down test.. Ticking definitely started when it overheated , and its definitely coming from #7. engine has lost alot of power. Which make me think a cam lobe might be worn down as well??
    NJ
    Temp gauge was pinned at what temp? It got at least how hot? 230* is where damage starts to happen.
    General loss of power could be rings losing tension, very likely from a bad overheat. Do a compression test and post your numbers. Since you said you did a compression test previously, post those numbers too. If engine still runs fairly smooth just a lot less power I'd suspect fairly uniform loss of compression and not just a single valve having a problem. Could be cam wiping a lobe or bend pushrod, also possibly bent valve but less likely. Though at high temps parts expand and clearances decrease. Oil also breaks down and offers much less lubrication or will coke on surfaces reducing clearances.
    Sounds like you've identified bad valve componenents that won't take up lash. You take out lash enough to quiet it down and valve hangs open causing a misfire. Pull the pushrod and check for straightness. Inspect rocker fulcrum for abnormal wear. Inspect valve tip for abnormal wear. Try to get an idea if valve stem may be bent but this can be hard to tell without removing it or at least getting the spring and retainer off. If nothing obvious there, you may have wiped that cam lobe. You'll have to pull the intake and inspect that lifter to get a better idea if you find no obvious issues with the other parts. Hot oil breaking down and not lubricating, could have begun to seize that lifter or valve damaging the cam. Is it an intake or exhaust valve that is making noise?
    It would not surprise me if the cam is wiped, but I wouldn't just straight to that as the sole issue.
    Most auto engines today run normally at 220-230 I doubt you caused any internal damage to the engine without melting the rubber hoses first. I would guess a bad lifter is the culprit. Some engines have large enough holes in the heads to allow sneaking in a new lifter without pulling the intake. If the cam is rounded I would think it was due to poor oil quality and thinning with the higher heat. If you pull the lifter you will see damage on the bottom where it contacts the cam that will indicate a bad cam. If its clean and not damaged so is the cam.
    Tacoma, Wa
    I wonder if it tuliped a valve
    2003 Supra Launch 22SSV
    1986 Ski Natique 2001
    NJ
    Care to name a few?
    most likely need to reset the rocker arms, they come loose at times. good luck
