I recently purchased a 2001 Sunsport and have a number of questions about it. I'm trying to figure out some of the switches (see picture below). There is one that says "heater" but there is only one wire attached to it and it goes from the switch to F1 or F2 on the circuit board under the dash. The other switch I am confused about is the "Trim up/down". It also only has one wire going to it and it goes to F1 or F2 on the circuit board. I didn't have a meter with me, so I didn't try to figure out which was which. "Accessory" I assume can be wired to be whatever you want. Any ideas what these do? They don't seem to do anything when I flip them. If trim up/down has something to do with the wake plate, that would not make sense, because I have a manual one.
Other big question is ballast. I have what looks to be the factory hard ballast tank under the rear seat. How do you fill/drain this? I don't see a switch for it, and it looks like there are two places for hoses to be connected, but there are none. Any information on this would be greatly appreciated!
Thanks guys!
01suprasunsport (1).jpg01suprasunsport (4).jpg20140330_163142.jpg20140330_163206.jpg20140330_164356.jpg
