Originally Posted by
mpiller
Ok so I was in a hurry earlier and believe I may have had the digital multimeter on the wrong setting. Just rechecked the batteries again and the older one put out 12.75 volts without the motor running or anything drawing on it. The new battery put out 13.14 volts again so it looks like my older battery should be fine? Gonna try to put the boat in the lake in a bit and start the motor and see what results I get this time. Basically from my understanding the alternator should be fine if the batteries jump to a little over 14 volts once the motor is running? Really hoping this could have just been from the other battery being dead last Saturday.
Thanks guys
You can always take the battery to an auto parts store and have them load test it. That will tell you if your batteries are good, and it's free.
-Mike
2006 Supra Sunsport 20V
