'88 sunsport dash switch/electrical question
i've been looking to replace my stock dash switches/buttons as they are tempermental quite often, to where some of them won't stay depressed until i push them about 20 times. with that in mind, i was out the other night and was running my new ronix 3700gph ballast pump (20amps) and flipped on my bilge pump at the same time. this may have been a coincidence, but the main ignition switch/button popped to the off position within a couple seconds. a couple button pushes and i was able to start the boat back up without issue, but every time i would try to use that pump or the other front sumo pump, it would work for a bit then i'd lose power again. i'm not certain whether this is the switch or if something's wired incorrectly, causing the 15A dash switch/buttons to pop frequently. does anyone else have this issue? this only happened once last season that i remember, where the main ignition switch popped to the off position, so i'm not sure if it's just needing replacement or if it's triggered by something.
my initial thought is to replace them all with toggle switches, so that i don't have this issue anymore. however, do i need to put a 15A fuse inline to the toggle switch to match what the factory put in? the stock switch replacements are ~$22 on skidim which is WAY too expensive to replace all 8 or so. if i don't use a fuse at all inline with the new switches, will i potentially have a different failure point in the wiring system? i have to re-do some of the stereo wiring to begin with, because the PO had wired some things through a relay which, when having no amps in place to use the inline remote wire, causes the depth finder that's on that same relay to not power on. or can i just install new toggle switches everywhere without issue? the other dash switch that constantly pops to 'off' is the cigarette adapter, whether i have something plugged into it or not. really annoying...i'd like to take care of this once and for all!
thanks in advance...
