carb/idle help
I have read through the earlier posts about carb adjustment and followed everything to a T. Here is my situation, 351 PCM with Holley 4160, 1.23:1 Trans, protec ignition, new choke set at 2 lines rich from stock, new fuel pump, mixture screws 1.5 turns. Starts and warms up fine, idles fine when put onto gear for a little while. Idle is set @ 800RPM however pretty sure my tach is off sounds lower than that. Anyway as the engine continues to run when I put into gear it stalls out. If I want to keep it running I have to bump the throttle which when picking up skier or docking is NOT fun.
-cjtpilot...........1992 Supra Comp Ts6m..........351 PCM
Big Air tower
Radar Theory Slalom, Fulltilt wakeboard, barefoot.
