So, over the winter, I picked up a cool gadget. It's a waterproof remote control for my perfect pass. Basically it has an up arrow and a down arrow on the remote and you can either fasten it to the rope for wakeboarding or line riding surfing. Or you can wear it on an armband. The arrows do exactly the same thing as pressing the up/down arrows on my PP.
I got a sweet deal on ebay and worked it out to have an extra remote control for kicks and giggles.
When I was inquiring about the product, the owner was crazy fast on his replies. I asked him a question on ebay and had a response within an hour. After that responses were within minutes. Amazing customer service and a really cool guy. Their website is http://www.tantrumtowropes.com/.
The install was ridiculously simple. There is a control box with a male and female harness that obviously bridge the connection between the PP display cluster and the PP ECU. Then there was a red wire and a black wire. If I can't figure out that those go to Pos and Neg, I need to have my DIY status revoked. I had it installed in literally a few minutes.
I did pull out the instructions to program the remotes. That was crazy easy too. Press the program button for a few seconds until it lights up. Then press a button on the remote (or in my case each remote) and DONE. I with programming garage door opener remotes was so easy!!!
And that's all there was to it. The control box has mouting tabs, so I put it next to my Perfect Pass ECU box.
Tantrum Wireless control box:
Perfect Pass ECU box. Pretty obvious what cable this uses. Also I chose the lazy route and just tapped into the Positive and Negative going to my PP.
All mounted and installed.
And for what it's worth, I have the Perfect Pass Wakeboard Pro:
I tested it out and it worked as expected. Pressing the arrows on the remote was just like pressing the arrows on my PP cluster. I'll report more when I've had a chance to water test it, probably in a few days.
