Ok sum it up I have been chasing a water leak, tightened prop shaft and rudder. However take it out and run it and I still have water coming in from somewhere........ From the engine back in the center section is good. However I noticed the left rear carpet was wet yesterday. Could it be fro the water coming thru the exhaust manifold into the floor? I looked from the rear inside the exhaust and the only place I can see is about 6inches in it looks like maybe there is a attach point with a gasket that could leak? Otherwise it is a strait wide open tube to the hose coming off the manifold.
