A bad PCV will cause idle issues and keep you chasing your tail if you never think to check it. I just rebuilt my carb and ended up having my idle needles turned out 2 turns. yes adjusting your idle mixture screws will effect idle RPM. Set your screws with the idle adjustment all the way out, then after you set the mixture screws with a vacuum you can adjust the idle speed. Typically around 650-750 RPM. Which trans do you have 1:1 or 1.23:1? if you have the 1:1 then you have to adjust float level to make up for the carb sitting on an angle. Otherwise the engine and carb should set level, at least it does on a Comp.
-cjtpilot...........1992 Supra Comp Ts6m..........351 PCM
Big Air tower
Radar Theory Slalom, Fulltilt wakeboard, barefoot.
