Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Sep 2004
    Hudson, WI
    It could also be that there is another point with a bad ground that feeding into your system. If the cigarette lighter or lights have a bad ground, you could have the same problem.
  2. #12
    Mar 2008
    Orting, WA
    Oh man seriously! I hope I eliminate it on the first try, chasing it through the other accessories sounds like zero fun...
    08 Launch 22SSV
    Orting, WA
  3. #13
    Lake Wylie NC Area
    An RCA cable, such as a stereo RCA, is comprised of a left and right channel. each plug is positive and negative. These carry an A/C audio signal, so that outer RCA negative, should not be a direct chassis or 12V DC ground. In most cases we come across, it is just that, DC on the signal negative, that is the source of the noise. 9 of 10 cases, its a result of the audio gear drawing from different battery sources.
    Michael
    Mikes Liquid Audio
